Sounds like your saving with the wrong post processor.
Hi I use v carve pro 8.5. I designed a project much like I always have except I didnt import any image. I simply want to make a 30"x19" piece with 1/2" slots every inch. I used the lines and rectangle section to do that. But when I try and download it onto the cncsb it says- "Error in G code. File ended with no percent sign or program end (10) Line: 1506 Go X0.0000Y0.0000". Also the file after I saved it ends with nc not tap. example: name of project.tap instead it has- name of project.nc. What am I doing wrong?
Thank you
Ray
UCCNC 2017 Screenset
The .NC file may work depending on your control software, however you can select your POST when you save your file....see attached
I saved it inn G Code
Got it Thanks guys
