Needing a How To for a Scallop
Results 1 to 3 of 3
Thread: Needing a How To for a Scallop
    Dec 2014
    Default Needing a How To for a Scallop
    Wanting to understand how I make a Scallop action to achieve a Tractor Tire Look. My Understanding is the shape around A-B would be a Circle on say a 45 degree angle so that the circle would hit A at 12mm ( Material would be 12mm Thick ) then B would be like 4mm remaining. If anyone has a favourite YouTube clip showing how I can acheive this would be Fantastic
    Attached Thumbnails Attached Thumbnails Needing a How To for a Scallop-wheel-jpg
    Mar 2008
    Default Re: Needing a How To for a Scallop
    Ken...
    Pic 1:
    I used a similar shape to your tread segment and copied it around a circle (smallest). Joined them all with a smooth curve.
    Then offset the circle to outside the treads (largest), grouped them for a VCarve toolpath
    Pic 2:
    I then took a copy of the tread pattern and the middle circle, welded keeping outermost
    Pic 3:
    Did a profile outside the welded vector and vcarved the joined
    Attached Thumbnails Attached Thumbnails Needing a How To for a Scallop-tire-1-jpg   Needing a How To for a Scallop-tire-2-jpg   Needing a How To for a Scallop-tire-3-jpg
    Gary Campbell GCnC Control
    Servo Control & ATC Retrofits
    Dec 2014
    THANK YOU for that, much appreciated!!!!
