Results 1 to 9 of 9
Thread: thermoforming white film on clear parts !!!
    Jan 2010
    hi all . i work for a sign company and last year i took over the thermoforming process. i know nothing about it. the whole process i am learning as i go. i have a female mold that has an MDF base and i am pulling 3/16" polycarbonate that is clear. i keep getting an white film on the face of my part???? i need ur help. when u get a chance. any ideas??
    Jul 2004
    I'd cruise over to the tk560.com forum and ask there.
    while you do that, describe the tool, and the process temps.
    Also what masking came on the part, cling film or acrylic glued
    clear film. are you forming film on or off, how big a part, what
    machine etc......
    Scott.
    Jul 2005
    Are you baking the polycarbonate before heating it for forming. Polycarbonate adsorbs water into the surface and if this is not driven out by a low temperature bake before heating to forming temperature it can cause the formation of bubbles.
    Jan 2010
    the mask on my poly-carb is a cling type mask. i am forming with the film off. the part size is 36"x42". the part is a embossed pan sign face. max depth 2". the top of the mold is made from mahogany, then the draft angle is made from repro, and the bottom plane of the mold "face surface" is made from MDF. this area is where i am having the white film transfer. our mold maker prepped this surface with sanding sealer, then liquid wax . . .is this wrong? is this where my mysterious white film transfer is coming from? THANKS
    Jul 2004
    absolutely wrong. never use something that melts below forming temp on any mold. You might get away with wiping the formed part with NAPTHA. This degreases most lexan smear problems. I also have very good luck with Methanol for cleaning........ Scott.
    Jan 2010
    I was under the impression that NAPTHA would "melt" my formed part??? This would not be good as is this is a clear sign face and has to be 100% translucent. THANKS
    Jul 2004
    I manufacture lexan windshields, Naptha removes marking inks very well, Methanol is good also. MEK and Acetone will destroy lexan really fast. the reason I said you might get away with it is that I am uncertain of the soluability of your sanding sealer in Naptha, not that that I was concerned for the health of the plastic.....
    Jan 2010
    Ok so is there a certain brand of naphtha that i should try? also what is the application, and or the removal process. i have tried some and it just doesent seem to be working.
    Jul 2004
    I'm fairly certain you are getting smear off the tool. There are basically 2 possibilities here. 1) that it is removable with the proper plastic friendly solvent. 2) That there is a reaction occuring involving the "stuff", heat and the lexan itself. If tha3ts the case I cant help you.
    Naptha is a generic solvent, nothing exotic about it. Wet a cotton cloth wipe the plastic wet and look to see if the smear comes off. Methanol sometimes gets stuff Naptha wont touch, try them both.
    But most importantly, fix the tool........
    1. Aluminum molds for thermoforming
      By fer_mayrl in forum Vacuum forming, Thermoforming Etc
      Last Post: 01-02-2011, 06:09 PM
    2. masking film
      By 1ctoolfool in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 06-28-2009, 09:42 PM
    3. New To Vacuum Thermoforming Help Please.
      By MLP F1 in forum Vacuum forming, Thermoforming Etc
      Last Post: 05-12-2009, 09:23 AM
    4. Thermoforming Nylon
      By dpryor in forum Vacuum forming, Thermoforming Etc
      Last Post: 07-22-2008, 08:15 AM
    5. SE USA Thermoforming Source?
      By hlsjls in forum Vacuum forming, Thermoforming Etc
      Last Post: 07-10-2008, 03:49 PM
