Results 1 to 10 of 10
Thread: Solid material alternative to epoxy?
    Apr 2009
    Does anyone have experience or knowledge of a machinable material that can be used for vacuum forming polycarbonate? Basically start with this material, machine to form, clean surface finish, use as a mold?
    Currently we use an aluminum filled epoxy, there is so much back and forth work to create the mold I have to imagine there is a more direct way.
    Thanks for your time!
    Jun 2007
    us
    This is nice to work with but pricey.
    http://www.freemansupply.com/RenShapeModelingan.htm
    This stuff is a porous metal,.. even more pricey
    http://www.portec.ch/thermoforming.htm
    This is my favorite two part casting resin, cheap, easy to mix and use, and it machines nice.
    http://www.bccproducts.com/castingmaterials
    Jul 2007
    New Zealand
    Casting resins
    I have been to the BCC site are there are some very interesting products, which casting resin do you use?
    Gill A
    Jun 2007
    us
    I use 8001 Kwik Kast resin.
    I also noticed they have tooling boards.
    If you want inyeresting products, Try this
    http://www.polytek.com/
    Jul 2007
    New Zealand
    prices
    Thank you kayaker,
    As the site does not have prices can you tell what price they charge.
    Jun 2007
    us
    Polytek does have trial sizes for many of their products, but overall they are competitive with others. In other words pretty expensive. They do have some very unusual stuff though. They put out a users manual/catalog for around $10 that's worth getting
    The BCC Kwik Kast resin is about half the usual price and easier to use than anything else I've tried.
    Jul 2007
    New Zealand
    Polytek?
    Thanks again for your input.
    Where and how can I contact Polytek, I take it they sell the BCC product?
    Gill A
    Jun 2007
    us
    Google is your friend,.. http://www.polytek.com/
    BCC industries is a different company,... http://www.bccproducts.com/
    Gold Member eaglezsoar's Avatar
    Feb 2010
    Has anyone tried the Metal Cast from Bccproducts?
    Regards, Carl
    Mar 2004
    Sweden
    I've been using Ureol, which is a sort of predecessor of RenShape's block material. Very easy milled and form stable.
    1. Alternative Material
      By Jim Mill in forum General Metalwork Discussion
      Last Post: 12-30-2006, 07:05 PM
    2. Alternative Material
      Last Post: 12-30-2006, 03:08 PM
    3. Which came first, Solid Edge or Solid Works?
      By Arnie in forum General CAM Discussion
      Last Post: 09-15-2004, 07:25 AM
    4. Quartz filled epoxy...
      By karmicthre in forum DIY CNC Router Table Machines
      Last Post: 06-22-2004, 09:30 AM
    5. Alternative material for gantry parts
      By owhite in forum DIY CNC Router Table Machines
      Last Post: 02-10-2004, 01:26 AM
