DylanF welcome aboard! And you too
05fmtc!
Check out joewoodworker website for some basic ideas to incorporate your degassing pump (system) into other projects. Yes, he is focused on doing veneer work - but the principles are the same and a good free pdf build "log" too. Not sure which way you were pointing fiberglasing -- or vacuum forming - so try these ideas:
For FIBERGLASS VACUUM BAG setups:
Most "slick plastics will not stick to your resin.
For your vacuum bag - if the project is dual; sided - use the HEAVY DUTY - OVERSIZE zipLock bags. If on a flat surface, you can pick up a clear shower curtain! Cheap as chips and effective. TO hold down - brown packing tape - but make sure you check is compatible before buying a case!
Yes - poly will "cook" early - BUT you can work with it that way in a vacuum system - just need to have it promoted correctly. Helped build a 54 ft catamaran 's hulls - using the process -- with polyester!
But
svenakela is right - you should build and use a resin trap to save your gear!
For peel ply - you can substitute NYLON ( like parachute cloth) - way cheaper and just as effective.
In the Uk can't say who is best buy - but here in the US - you can't beat uscomposites -- (and I had to pay FL sales tax too).
FOR THERMOFORMING:
I'll post some pics of my recently completed vacuum setup - and I'm building a thermoforming deck for it - then a separate heating platform too. One thing at a time.
Check tk560 web site for a few good thermoforming heating element build logs too.
Any more questions - just ask!
Jim
