Results 1 to 5 of 5
Thread: Vac forming ABS 10foot long x 2"x1" chanel
    Apr 2008
    United kingdom
    Cool Vac forming ABS 10foot long x 2"x1" chanel
    Hello, Im new to vac forming but have jumped in at the deep end so to speak. My aim is to produce two chanels in a 10 foot x 21" sheet of 3 mm (3/16") ABS. Each chanel is to be 2" wide with a depth of 1" and equal distance from the sheet centre line. I have a 25cfm vacuum pump and a 50 litre vac-reservoir. I will be using a male mould (without draught angle). My question is - "Can anyone assist with ideas on how to heat the areas to be formed?" To date Im toying withe the idea of running 4 nichrome wires the full 10foot spaced at 1" apart (bottom heat). The closed oven will be fully enclosed and constructed from aluminium faced plasterboard. Initialy I will attempt to form one chanel at a time. I would dearly welcome all input and thank you in anticipation.
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    If you only have to make two of them it might be less expensive to have a local plastic sign manufacture do the vaccum forming. They have the oven and do this work daily.
    See this link for idea.
    http://www.hansonsign.com/plastic_info.shtml
    Jeff Alessi
    Jun 2007
    us
    First of all can you even find 10 ft long sheets? Its not a common size.
    I think you will have to heat the entire sheet up till its soft and form both channels, it never works well to try and heat part of a sheet. This will take a tremendous amount of energy. I use 1200 watts per square foot so use that as a basis for calculating but it would need around 100 amps at 220 volts. Do you have that much power available?
    If these channels are just straight bends the full length of the sheet, look up a process called line bending for a much easier solution. Easy to build, low power requirements and no vacuum needed.
    Apr 2008
    United kingdom
    Thumbs down
    Quote Originally Posted by jalessi View Post
    Jeff Alessi
    Thanks for that Jeff, but I'm talking of two per sheet and not two in total. I have several hundred sheets to form. Do you think I would have bothered anyone in a forum based upon two only? -- duh!
    Mar 2004
    Sweden
    Quote Originally Posted by fencer View Post
    Yes, why not?
    I have been producing many items in just one ore two pieces, and even more if we count to ten. It's just a matter of money. If someone needs a prototype, they'll pay.
    1. "low end" HF Spindle or "high end" router for about $1000?
      By biomed_eng in forum DIY CNC Router Table Machines
      Last Post: 01-06-2012, 01:15 AM
    2. BattleAxe "aka" Ball and Chain "aka" the wife.
      By ZipSnipe in forum CNCzone Club House
      Last Post: 05-18-2008, 10:53 AM
    3. G320 "common" or "+5vdc" why do they vary?
      By beezerlm in forum Gecko Drives
      Last Post: 01-12-2008, 05:00 PM
    4. Has anyone looked at the "JET" or "Shop Fox" manual machines?
      By boosted in forum General Metal Working Machines
      Last Post: 03-04-2007, 10:33 PM
    5. Vertical system "jerks" and "bangs"??
      By REVCAM_Bob in forum Servo Motors and Drives
      Last Post: 06-12-2006, 10:09 AM
