only thermo-plastics can be re-used, thermo setting plastics are normally not, due to being very brittle and high temperature resistant, they will burn first (i.e. bakalite.)
Hi All!
This is probably a stupid question to ask....but if plastic is heated and then vacuum formed, can the 'scraps' that were cut off, be re heated and used for a smaller piece to be formed? (using a much smaller frame of course)
Just thought I would ask. I hate waste.
Sunshine
Since we only use thermoplastics for vacuum forming the answer is yes,... Provided the scrap is big enough and flat enough to go into a clamp frame. You might expect some degradation though especially if it was overheated slightly the first time?
Better to just use the right size sheet to start with, then re-cycle the scrap.
Thanks,
I was just curious.
I had thoughts of making a small frame for doing really small forms. And thought maybe scraps might work. I think you are right...-recycle.
Then a question my son asked me .... can 2 liter soda bottles.... be cut open and used ? (The mid section..)
I would think the piece I form- I could use 1 or 2 times as a mold for my crafts. (I play with cement))
Any comments on this would be appreciated.
Sunshine
Sure, many people use soda bottle plastic to make model airplane canopies etc.. I think they are made of PET-G which is one of the easier plastics to form.
