Results 1 to 7 of 7
Thread: using clay as mold
    Jun 2007
    using clay as mold
    i am good with clay, i took clay arts classes and sculpting, so when i made my stormtrooper faceplate it took about an hour if that to complete it. my question is, since im going to be only making one stormtrooper costume, can i use dried clay on the mold surface? its fully dry, and pretty sollid and the walls are pretty thick. oh and the back to keep it from falling is compacted with compact newspaper, its so compact, i cant even get the damn thing out if i wanted it to
    but im askin has anyone tried dried clay as their mold?
    how many pulls so you think it would last?
    Gold Member High Seas's Avatar
    Sep 2003
    Malaysia/Australia/NZ/USA
    Quote Originally Posted by djtrickdog View Post
    No, but have used plaster of paris and bondo on some parts I pulled- maybe quite a bit "stiffer." What if you laid a thin layer of bondo over the mask first? Also some resin or something to "lock" the paper in place and make it really rigid. I did only 2-3 on the bondo but looked ok when done with it.
    Maybe that helps????
    Jim
    Have you seen the Baking Clay? I've used that to but not for a pull - used in a silicone pour app. It sculpts like clay then you bake in oven. Might be too expensive for bigger pieces.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Jun 2007
    Quote Originally Posted by High Seas View Post
    Jim
    ohhh trust me, the newspaper aint commin out lol thats what i made my mask on and when it dried, the kinda formed, plus, i wrapped the bundle of paper before i started in masking tape (since i get unlimited supply of that crap for free from my stepdads work). but the bondo idea, i might try that how should i even it out? just some latex gloves?
    edit:yah ive seen baking clay, its alot more expensive than potting clay. my faceplate which is about 2x thicker than it needs to be, cost about 6 bucks in clay to make. cheap !
    Sep 2005
    clay
    chevant is best
    Jun 2007
    Quote Originally Posted by silverfoxx03 View Post
    chevant is best
    whats that?
    Jun 2007
    Yes, you can use clay for the mold. I do it regularly. I use regular water based ceramic clay. Once you sculpt what you want, you can vacuform right over it, but you will get best results by letting it dry to a "leather-like" consistency before vac'ng over it. then use that pull as a mold, and pour stone into it for a more permanent mold.
    Then the stone sets, pop it out of the pull and it will carve like soap. You will be able to clean up any irregularities ffrom the clay pretty easily. Once it is completely set, you have a pretty tough tool.
    Registered drcrash's Avatar
    Oct 2006
    whats that?
    Chavant is a premium brand of non-drying modeling clay.
    It comes in sulfur free and sulfured versions, and several hardnesses. The sulfur-free stuff won't inhibit the cure of silicone, if you make a silicone mold off of it. The sulfured stuff will.
    Klean Clay is also sulfur-free, and cheaper.
    Another option is WED clay. (One source is Laguna Clay.) That's like water-based clay, but with glycerin and maybe some other additive, so that it dries slower and is less prone to cracking. It's often used for large sculpts because it's cheaper than modeling clay.
    1. Making a positive mold from a negative mold - how?
      By SRT Mike in forum Moldmaking
      Last Post: 03-29-2007, 05:30 PM
    2. Anti-vibration clay of sorts
      By JAVB in forum General Metalwork Discussion
      Last Post: 11-07-2006, 04:10 PM
    3. using cnc machine to sculpt clay ?
      By tree in forum Hobby Discussion
      Last Post: 10-14-2006, 12:18 PM
    4. Machining CM-70 clay
      By JohnG in forum General Material Machining Solutions
      Last Post: 06-13-2006, 07:06 PM
    5. rfq for mold
      By MBG in forum Employment Opportunity
      Last Post: 08-28-2005, 05:03 PM
