Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Vacuum forming, Thermoforming Etc
Vacuum forming, Thermoforming Etc Discuss Vacuum forming, Thermoforming Etc here.
Old 10-25-2011, 05:37 PM
achtung8 is on a distinguished road
Forming LDPE -
Greetings all, New at the forum.
I'm forming LDPE and need some guide as to how many holes I will need.
Currently have an Aluminum plate with two pockets in the inside. The hole size diamiter will be 0.0135 (#80 drill). I know its small but larger sizes are leaving severe dimples. Wondering if there is a ratio per square inch(s) I should be using. Thanks
Old 12-16-2011, 10:26 AM
jdougn is on a distinguished road
Vac forming usually doesn't require a hugh number of vacuum holes to work. I use as few as possible usually placed sparingly around the perimeter then in recessed detail areas. Without knowing details, sufficient vacuum is critical in pulling good detail. I don't visit here very often but am on another vac former forum, TK560 much more often. Hit the Discussion link towards the bottom of the left hand nav bar.
hth, Doug
When to use forming tap jeffrey001 General Metalwork Discussion 5 09-27-2011 09:31 AM
Metal Forming ???? BigBoy Solidworks 2 10-06-2009 11:26 AM
Vacuum Forming with PVC kaseencook Vacuum forming, Thermoforming Etc 4 04-25-2009 05:53 PM
Need Help!- Forming 1/4 CRS Chris@PREBOLA Bending, Forging,Extrusion... 5 02-02-2009 09:24 AM
Need Help!- die forming a metal box? andrew888 Diemaking and Diecutting 7 06-20-2008 12:05 PM
