| Vacuum forming, Thermoforming Etc Discuss Vacuum forming, Thermoforming Etc here. |
| Hello, I am as green as grass when it comes to plastic forming. BUT, I have lots of enthusiasm and am eager to learn. I would like to home produce / thermoform .020" flock covered styrene to make display case liners that are about 8" x 12" and 1" thick. Using a sample liner that I wanted to duplicate, I made my first plug ( terminology?) by layering the inside back with Tiger hair fiberglass. Removed the plug and now filling the voids and air pockets with glazing putty. What I would like to know is after the plug is filled and sanded, can I paint with lacquer primer progressively sanding with finer grit paper to achieve a semi glossy surface? Would the last step be to wax the plug before using? Will lacquer stand up to the heat of styrene forming? Thank you for your help, Bob |
| I would fill the tiger stuff with more bog or better still a polyester resin thickened with talc and trowel on. The resin talc mix will sand down to a very smooth surface. As you are flocking the part I would have thought it does not need to be that good a surface. You will be able to vac over the polyester talc surface without further treatment. |
__________________ J&M Enterprises | Ceramic vacuum form tooling www.jmenterprises.net |
| Unplugged Spindle Fan on 2006 VF2, cant remember which plug to plug it back into.. | locash | Haas Mills | 2 | 08-20-2010 12:41 AM |
| Made a vacuum forming table and mold for portable games console | bacteria | Vacuum forming, Thermoforming Etc | 9 | 11-06-2008 06:56 AM |
| aluminum forming...press mold? | mc-motorsports | Bending, Forging,Extrusion... | 9 | 08-17-2008 12:10 AM |
| Mold Finishing prior to forming | Cafemondo | Vacuum forming, Thermoforming Etc | 7 | 08-20-2007 09:37 PM |
| styrene | djtrickdog | Vacuum forming, Thermoforming Etc | 4 | 06-21-2007 11:44 PM |
