Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Vacuum forming, Thermoforming Etc
Vacuum forming, Thermoforming Etc Discuss Vacuum forming, Thermoforming Etc here.
Old 09-13-2010, 10:14 AM
jaysteel is on a distinguished road
Vacuforming acrylic
I'm having a problem I hope you can help. I'm trying to thermoform acrylic. I am using less than 1/8 inch extruded acrylic instead of cast acrylic to keep costs down until I have the application system completed. I am heating the material in a convection oven and vacuuming. The problem is I keep getting blisters. I've gotten blisters as low as 175 degrees - and of course at all higher temperatures. I've been told to preheat the stuff at 100 degrees for 24 hours to correct the problem. Any thoughts? Thanks
Old 09-14-2010, 07:15 AM
spektr is on a distinguished road
I think whats happening is that you have a problem measuring the sheet temperature. Assuming you are measuring it with an infared temp gage, you
could very easily overtemp the sheet surface without getting the core temps to a moldable number. Acrylic will only accept so much energy per unit time per unit area. If you exceed that number, you blister the surface before you can mold it because the core will still be too cool to mold.
A second consideration is residue from the masking. What was it masked with and how did you clean it?
Scott.
Drilling Acrylic gpraceman Glass, Plastic and Stone 2 07-26-2010 11:56 AM
All you'll ever need to know about gluing Acrylic kewlkiwi Laser Engraving & Cutting Machines 4 07-24-2008 10:17 AM
A question Concerning Acrylic velocitygraphix Hobby Discussion 1 01-14-2008 05:53 PM
Acrylic blfuller123 DIY-CNC Router Table Machines 3 12-28-2006 08:15 AM
Acrylic Mike7 Vacuum forming, Thermoforming Etc 2 10-30-2006 10:16 AM
