Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Vacuum forming, Thermoforming Etc
Vacuum forming, Thermoforming Etc Discuss Vacuum forming, Thermoforming Etc here.
Old 08-12-2010, 05:54 PM
andsetinn is on a distinguished road
Vac forming machine build Qvack.
Hi.
I thought I'd share few pictures of my homemade vac machine. I didn't follow any particular design, it's just built out of stuff I had lying around and the form follows the function. The tools used are circular saw, jigsaw, hand-held router and battery powered drill. I had to name it something so I chose the name Qvack, from vac and Quack.
First the vacuum table. As you can see there are no supports for the table. I believe it's thick enough not to need them.
With "vacuum-cleaner" motor. There are similar motors are inside many vacuum cleaners.
Motor "installed".
Machine "skeleton".
Plastic holder installed. Note the drawer-rails I use to slide the holder up and down. Much easier than building rails from scratch but I have to be careful not to load them sideways.
Materials for heater. Metal shelf and oven heater elements.
Heater built (the heating element still needs to be securely fastened.). That element is about 1300 watts.
Finished machine (although this kind of machine is never finished ).
Second pull, the first was utter failure.
Body from third pull. Still needs more work.
Does hitting yourself on the head, repeatedly, with a big, hard, box count as "thinking outside the box".
Old 09-19-2010, 02:04 AM
trophy is on a distinguished road
webbing
Please keep us informed of your progress as I would love to know how you get rid of the webbing (excess material) in the corners
Old 09-23-2010, 05:18 AM
svenakela is on a distinguished road
Wow! I really like the simplicity and the vauum cleaner motor idea. I've been thinking of making a simple former for some experiments (and to have the kids interested in work shopping). This better be the way to go!
Old 10-24-2010, 08:06 AM
Dzogchen is on a distinguished road
Please explain how you wired and control the heating element. Very nice job! I saw something on here about spacing your pattern up and lowering heat to avoid those problems, but I don't know anything about this stuff...Good luck!
Old 10-27-2010, 03:28 PM
The element is on or off. Just wired through a switch.
I reduced the webbing by raising the form a bit, roughing the outside a little, drilling few extra "ventilation holes" in the form and using Polycarbonate instead of PET.
Benny's Vac Forming machine (Work log) ynneb Vacuum forming, Thermoforming Etc 10 05-09-2010 02:31 AM
I'm going to build my first CNC machine jimmycakes Open Source CNC Machine Designs 2 07-26-2009 11:48 PM
Newbie- Anyone Actually Built Gingery Vacuum Forming Machine? billman Vacuum forming, Thermoforming Etc 0 09-29-2008 03:49 PM
Vacuum forming plastic machine. ynneb Vacuum forming, Thermoforming Etc 48 11-27-2006 05:23 AM
Vacuum Forming Machine ruihuamachine Vacuum forming, Thermoforming Etc 0 05-17-2006 08:03 PM
