Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Vacuum forming, Thermoforming Etc
Vacuum forming, Thermoforming Etc Discuss Vacuum forming, Thermoforming Etc here.
Old 03-12-2010, 01:17 AM
trophy is on a distinguished road
Lexan wave length
I am trying to vac form Lexan .007" and .020" thick with limited success.
I keep hearing about wave length, what does this have to do with the type of plastic one forms?
I am using 22ga nichrome coiled wire, not sure what effect if any the ga has has on Lexan.
How far above the lexan should the elements be?
At present it takes 20 seconds to heat the .007" Lexan to a droop.
All help appreciated
Old 03-12-2010, 01:40 PM
spektr is on a distinguished road
wave length.... It is usually referring to the IR part of the spectrum that the emitter transmits heat with. Usually has very little to do with forming, the plastic sees heat, the wavelength of the heat just changes the rate at which things heat up. There is some optimization available, but when cal-rod, nichrome wire and quarts lamps all have about the same effectiveness on plastic, with heating times within seconds of each other, I tend to not worry a lot about it.....
How did you like the Aussie Supercars in Bahrain?
Scott.
Old 03-12-2010, 02:05 PM
wave length
Hi Scott,
thanks for the speedy reply.
Yes loved the V8's at Bahrain.
My current project (1/24th slot car body's) is making the latest Holden and Ford cars as raced at Bahrain.
Any ideas how I can get rid of the big bubbles that form on the bonnet and roof, I have sanded with 240 grit but has not helped.
Tried .020" holes but they show up in the finished parts.
Gill A
Old 03-13-2010, 08:25 AM
VETTEL IS ON THE POLE IN BAHRAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Get some 100 grit drywall screens and LIGHTLY sand the roofs.
The issue is usually the fact that large smooth areas seal off
before getting sucked down. My headlight lenses do the same
thing in mold tryout. Also strategically located xacto knife scoring
works well turning corners. Take a #11, my favorite, and with
the handle perfectly vertical, put the point of the blade on the
roof of the car. Rotate the blade 90 degrees and pull it towards you.
This makes a small v shaped notch. Keep the handle perpendicular-ish
to the mold surface and make mini-grooves around the corners.
.005 inch / 5 thou should do it without transferring to the surface
of the part. Try the screens first and remember to wrap around
the roof contour down the body sides just a bit to give the trapped
air a place to go ..
When are you sending me a couple bodies? I bet they ship better than
a good southern beer.......
Scott.
Old 03-13-2010, 11:46 PM
drywall screens
Scott what are drywall screens.
and where does one buy them.
I have worked out what they are in fact I have some 10" disks but not called by that name.
I am sure the sheets are not available her in NZ.
Who knows what the mailman will bring.
Go the Holden to you guys there GM.
Old 03-14-2010, 12:56 AM
MyCattMaxx's Avatar
MyCattMaxx is on a distinguished road
Drywall screens are sheets that look like a screen, has holes all over it.
010001110110111101110100001000000100110101101001011000110110010100111111
Maxx
Old 03-14-2010, 06:19 PM
Imagine window screens coated with 100 grit media. Its for sanding down drywall mud after you tape the wall. Drywall in the states is the gypsum boards with hard paper facing we use for interior walls. I'm sure you guys have a similar product. Where they sell taping tools they should have it.. If not, GENTLY use 100 grit sand paper. just light surface scratches, not material removal. The scratches promote evacuation of flat surfaces.....
CRAAAAAAAP Vettel broke a header and settled for 4th.
COOOOOOOOL Schumacher was a non factor..
2 weeks to the AUSSIE GP........
Whats Nascar?
Scott.
Old 03-14-2010, 06:25 PM
MyCattMaxx's Avatar
Nascar is a race with 2 rules. Drive fast. Turn left...lol
Maxx
Need Help!- Lexan Clearity! truckmann4x4 General Material Machining Solutions 6 04-26-2009 07:13 AM
Need Help!- Lexan supplier trophy Vacuum forming, Thermoforming Etc 2 04-10-2008 03:31 PM
finishing Lexan qmas99 General Material Machining Solutions 8 07-02-2007 07:45 AM
saw slitting lexan recoton Glass, Plastic and Stone 5 07-02-2007 04:54 AM
Tricool TC1 and lexan ckhalford Benchtop Machines 2 05-20-2007 04:47 PM
