Newbie Can you use ABS plastic to do VF?
Results 1 to 9 of 9
Thread: Can you use ABS plastic to do VF?
    Dec 2007
    Default Can you use ABS plastic to do VF?
    Hi Guys
    I am just wondering if I can use Black ABS plastic for VF because there is some products I want to make and I want to know if I can use Black ABS plastic?
    Apr 2006
    Absolutely, ABS is commonly used for vacuum forming applications.
    Dec 2007
    where can I get this black abs plastic at? because I need to make some automotive parts.
    Dec 2007
    why johnd? because you a dealer or something
    Feb 2006
    You should be able to find a local plastic distributor.
    Just make sure to specify thermofoming grade.
    Doug Pryor
    David Wolfe Design, Inc.
    Akron, OH
    www.davidwolfedesign.com
    depryor@davidwolfedesign.com
    Registered bacteria's Avatar
    Oct 2008
    England
    I hear though that ABS plastic is quite brittle, in comparison to other materials? I have been using Plasticard (Styrene), excellent material and strong.
  7. #7
    Mar 2011
    UNITED STATES
    Default ABS
    ABS is a great vacuum form plastic. It bonds to itself and is great for making figurines and other little projects. If you need places to buy it, try Your Source For Plastic Sheet, Slab, Rod and Tube. 866-832-9315 or High-Tech Plastics They have sheet and rod in many different sizes and thicknesses.
  8. #8
    May 2011
    bolivia
    where i can buy a good small prototype abs mmo mdf or any propyleno hard plastique machine 3d extrution
  9. #9
    Registered J&M Enterprises's Avatar
    Sep 2011
    ABS is one of the most common, and easier to form types of plastic sheet to thermoform.
    J&M Enterprises | Ceramic vacuum form tooling
    www.jmenterprises.net
