Vacuum Forming HDPE
Results 1 to 1 of 1
Thread: Vacuum Forming HDPE
    Dec 2016
    Default Vacuum Forming HDPE
    I have a forming machine that measures 24" x 36". We use 1/8" and 3/16" sheets of HDPE for forming. We are getting lines in the hdpe from where the plastic kinks up when you heat it. Is there any good way to cure this problem? We have tried unclamping the plastic until it sags, cutting the sheets down shorter, preheating the sheets, controlling temps and wind, etc. The lines are never in the same spot. They are very shallow. I never have any problems when we use ABS or polypropylene. However, HDPE is our material of choice.
    Attached Thumbnails Attached Thumbnails Vacuum Forming HDPE-15697238_819437135728_3812277064671835940_n-jpg   Vacuum Forming HDPE-15622731_819437190618_4428495305222541294_n-jpg   Vacuum Forming HDPE-15589576_819437105788_3860021988603917310_n-jpg
Vacuum Forming HDPE
Vacuum Forming HDPE
