Thanks for for the positive attitude, I'll put on some yee ha dance music and pratice a few steps. Being that my up and down is air assisted and my heat hood is a constant I will go to manual and use a couple of blocks.
Also, as I have an exhaust ean close by I'll cover it up so that it doesn' pull air from under the heat panel. do you think I should attach a foil skirt around the hood?
Ah, it's another day in paradise! i couldn't locate a temperature gauge to double check consistancy of temperature under the hood, will pop over to graingers on Monday.
