- Making use of a surplus oven.
Is it possible or advisable to use a heat shrink tunnel as an oven for thermoforming. I have one that can go to about 600 degrees that is not being used. Our thought is to clamp our material to a frame and then put it on a stand in the tunnel. Then remove it and form on a vacuum table.
Do-able????
- You may not post replies
- You may not edit your posts
Forum Rules
