DB25 Parallel Connection to USB on Breakout board for CNC Router
Results 1 to 6 of 6
Thread: DB25 Parallel Connection to USB on Breakout board for CNC Router
    Feb 2016
    Question DB25 Parallel Connection to USB on Breakout board for CNC Router
    So most of your breakout boards have either the DB25 parallel port by itself or with an optical coupler. Now my question is since the breakout board needs a parallel connection from the board to the computer can you use a converter that switches the DB25 to USB and still have the same functionality as if it was DB25 to DB25? or would it be beneficial to get an adruino board and make my own self contained system with a monitor for programming the CNC Router? If anyone can help me out, I would greatly appreciate it. Thank you.
    Wes
    Member jalessi's Avatar
    Feb 2007
    Default Re: DB25 Parallel Connection to USB on Breakout board for CNC Router
    Quote Originally Posted by robertsonwf View Post
    Answer: No
    Answer:
    See this thread:
    http://www.cnczone.com/forums/genera...-software.html
    Wes
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2016
    Thanks Jeff for the info! Now with that being said, do you have any recommendations for a good breakout board? I have come across a few that range from 3 axis to 6 axis but from overseas and being new to this I am definitely confused lol
    Feb 2007
    Post Re: DB25 Parallel Connection to USB on Breakout board for CNC Router
    Robertsonwf,
    CNC4PC makes a inexpensive ($28.00), buffered, very reliable, up to six (6) axis parallel port breakout board.
    http://www.automationtechnologiesinc...ional-breakout
    http://cnc4pc.com/Tech_Docs/C10R10_USER_MANUAL_V2.pdf
    If your P.C. does not have a parallel port Siig has the extremely compatible DP CyberParallel PCI model.
    CyberParallel | eBay
    Jeff...
    Feb 2016
    Jeff or anyone else that would like to chime in on this,
    So since I don't want to use my laptop or a desktop, I thought of building my own computer for the CNC Router in which the motherboard has a parallel port on it to accommodate that issue. Now with this being said do you think this would be and ideal view to solve my problem? to give you a full visual, I would buy all the internals for a computer but use it strictly for my CNC Router and have everything housed inside a custom case and have a small monitor for the programs and such so instead of using a desktop or laptop, its more portable in my mind plus depending on the setup of the system, you can house all of the routing plans and if need be code right there!
    Now another question that I have is that after getting my Stepper Motors, Breakout Board ( that you listed or one similar), Drivers and Power Supply, can you think of anything else that I would need electronics wise? I will try and answer this tonight if you reply or if anyone else does but if anything I will do it after work tomorrow. Thanks thus far for all the info being sent my way.
    V/R,
    Wes
    Feb 2007
    Wes,
    Check your P.M. mailbox.
    Jeff...
