Results 1 to 2 of 2
Thread: Simple sheet/plate parts, trying to get my first desktop CNC started!
    Nov 2009
    Just trying to get my first desktop CNC router started! I'm doubling the size of the ShapeOko open source router....I have my electronics, and hopefully this will be a fairly low cost testbed for future bigger and better designs.
    I need the following:
    (.125" THK 4130 or other rigid steel)
    1. 4x of the front/rear brackets
    2. 6x of the vertical risers
    OR
    (.25" THK 4130 or other rigid steel)
    1. 2x of the front/rear brackets
    2. 3x of the vertical risers
    FINISH: Raw, but all burrs and sharp edges must be removed.
    Whatever material you have laying around and can help me out on! This is my first desktop CNC I'm building and will be a testbed for bigger designs down the road. See DXFs in ZIP file attached.
    Attached Files Attached Files
    Nov 2009
    Alternate front and back plates attached below.
    Requirements for alternate plates:
    .1875-.25 THK
    4x (low end material thickness) 8x (high end THK) plates.
  1. sheet metal and plate roller
    By gabriel mari in forum Bending, Forging,Extrusion...
    Last Post: 07-28-2008, 04:02 PM
  2. Aluminum: flat, bar, sheet, plate, tooling plate??????????
    By Dan S in forum DIY CNC Router Table Machines
    Last Post: 06-28-2007, 01:48 AM
