Results 1 to 2 of 2
Thread: GEAR MILLING RFQ
    Registered ChrisW's Avatar
    May 2003
    Lake In The Hills
    GEAR MILLING RFQ
    Please quote gear milling only.
    Blank will be supplied.
    Material 8620
    qty 100,250,500,1000
    Dxf file is for reference only to get an idea of tooth measurements.
    Dxf is a vision cmm scan.
    Dxf file was too big to uplaod. Pm me for dxf file.
    PDF drawing blank size.
    Angle of thread helix is aprox 20 deg.
    Any one can help me find proper measurements i would be grateful.
    2 files attached
    Please pm me with quotes or qestions.
    Thank you
    Attached Files Attached Files
    Jul 2011
  1. Basic Bevel Gear - Milling a valley for gear teeth
    By ngr1 in forum General CAM Discussion
    Last Post: 04-05-2012, 10:55 AM
  2. Source for cheap(er) gear milling cutters needed.
    By cjjonesarmory in forum CNC Tooling
    Last Post: 11-17-2011, 09:27 AM
  3. Need a Lagun Lathe Gear or Custom Gear Maker
    By douglasco in forum General Metal Working Machines
    Last Post: 01-12-2011, 09:54 AM
  4. Spr gear design and milling
    By youthreewire in forum Mechanical Calculations/Engineering Design
    Last Post: 02-27-2009, 11:48 AM
  5. Help need in Milling a gear with 72 teeth
    By brianklein in forum G-Code Programing
    Last Post: 04-30-2008, 06:19 PM
