Results 1 to 4 of 4
Thread: Quote for small job near Indianapolis, IN
    Apr 2012
    I am needing a quote for a job that is to be cut from 1/8 steel. There will be a 14.5" outer ring that is 1/2" wide that will have three tabs on the inside approximately 4 inches long pointing to the center. There is also a 3/4" wide rolled ring welded on the surface of the outer ring. I have a 3-D PDF drawing if you are interested.
    Mike
    Mar 2012
    Send a drawing to RobMcQuillen@Gmail.com
    Rob
    Apr 2012
    I'll look at it for you. send a drawing to jeffgriffith46147@yahoo.com
    Jan 2011
    Please send file to mweaver71@yahoo.com. I'm located in Central Pa.
    Thank You
    Matthew Weaver
    Back Country Machining
    mweaver71@yahoo.com
  1. Quote Needed for small parts 2,000 pieces
    By HIDesigns in forum RFQ (Request for Quote)
    Last Post: 01-25-2012, 10:29 AM
  2. Need A Quote- UK: Need a quote for small-ish steel plates
    By Philipf in forum Employment Opportunity
    Last Post: 04-05-2010, 03:02 PM
  3. Need quote for small project
    By matt1ga in forum Employment Opportunity
    Last Post: 02-17-2010, 10:41 AM
  4. RFQ - 3 small hdpe parts and 1 mdf part (Indianapolis)??
    By DistortedDesign in forum Employment Opportunity
    Last Post: 11-06-2008, 11:47 AM
  5. small part need quote 300 pcs.
    By joey1117 in forum Employment Opportunity
    Last Post: 02-15-2007, 09:08 PM
