Results 1 to 4 of 4
Thread: Large qty of 3d contoured wood like parts
    Jul 2004
    Hello All,
    I'm searching for a machine shop to assist me in a project that involves 3 axis CNC surface milling of very small wood like parts. The part is about 76 mm long and about 7mm wide) The Z height tolerances need to be pretty good--probably +/- 0.0005".
    Currently I can make 4-5 per hour using my single spindle setup (single 20Krpm proxxon) and am in the midst of preparing a multiple spindle fixture to allow me to make more in shorter time. The new fixture fits in a 3/4" collet and is clamped to the quill. It is currently mounted in an Industrial Hobbies mill.
    Once I demonstrate feasibility with the multiple spindle fixture, I would like to approach a machine shop (preferably in the Boston or Philadelphia area but anywhere is workable) with the goal of hiring the shop to produce a larger batch of parts than I would want to make on my own. I would be willing to share/adapt my spindle fixture design/jigging such that it could fit on your mill. For now let's say batches of 1000, with a starter test batch of 50-100 so that we can get any kinks worked out.
    The fixture currently holds 4-8 electric die grinders (20,000rpm proxxon spindles ). Other spindles could probably also be used (pencil grinder perhaps)
    Once the spindle fixture is mounted, there are no tool changes, so this may be a good opportunity to use a CNC Bridgeport that's not getting enough use. It should be relatively easy to make a fixture plate that holds multiple parts (16-32?)
    I would welcome suggestions and/or referrals. I can offer more information with a confidential disclosure agreement.
    -Matt
    Jan 2011
    Could you send a file?
    Matthew Weaver
    Back Country Machining
    mweaver71@yahoo.com
    Registered ChrisW's Avatar
    May 2003
    Lake In The Hills
    R K TECH MANUFACTURING LLC
    Send file to :
    chrisrktech@gmail.com
    Thank you
    Sep 2011
    China
    Hello Matt,
    Please send drawings to hugo@wizmetal.com
    Thank you!
    Hugo
  1. Parts salvaged from large copier - are they useable?
    By Neuport in forum Stepper Motors and Drives
    Last Post: 09-29-2011, 09:24 PM
  2. contoured path is faceted?
    By fjbart70 in forum Bridgeport and Hardinge Mills
    Last Post: 06-26-2011, 10:55 AM
  3. Handling large parts
    By cdlenterprises in forum General Metalwork Discussion
    Last Post: 06-15-2009, 12:13 AM
  4. digizing large parts with MicroScribe
    By an-cadsolutions in forum Digitizing and Laser Digitizing
    Last Post: 03-01-2008, 05:24 PM
  5. Large parts Molding techniques
    By MBG in forum Moldmaking
    Last Post: 12-09-2005, 02:44 PM
