Results 1 to 4 of 4
Thread: Aluminum socket spacer - price estimate
    Apr 2007
    I am planning out a cnc router project using 4 x 4 x 1/4 in Al structural tubing. (the type that has square corners) These parts are intended to just barely slide into the end of the tube and help with connections.
    I will need 25 each Al blocks made:
    - Al 6061 or equivalent
    - 3.5 x 3.5 x 1.5 inch + 0 / - 0.010 inch
    - the 3.5 square face flat to +/- 0.010 inches across
    - The 2 inch faces perpendicular to the flat square face +/- 0.1 degrees
    - The corners can be radiused if that helps, and in the end, probably will be.
    These parts will be entirely hidden, so there is not spec on finish, it just helps to support a joint from the inside.
    Right now I just need an estimate if this is a job that is more like:
    - $ 50
    - $ 100
    - $ 250
    - $ 500
    I live in Pleasanton, CA (not far from San Jose) and prefer to buy local if possible.
    Harry
    Apr 2007
    If any one would like to send an estimate to me privately, you can email to hnj@wirlnet.com.
    Harry
    Apr 2007
    closed
    Hi, thanks for the people that sent the info to me.
    As it turns out, the Al material alone cost more than I had any idea, so I am putting this on hold for now.
    Harry
    Jan 2006
    Harry
    Maybe you could use short lengths of aluminum angle to make your joints?
    You can get an idea of material costs here: Speedy Metals - 3-1/2" {A} Sq 6061-T6511 Aluminum, Extruded
    Matt
  1. Need A Quote- Aluminum Spacer Rings
    By morerice in forum Employment Opportunity
    Last Post: 10-06-2010, 09:04 AM
  2. Need A Quote- 40mm ODx 1.25 in ID x 4 in long aluminum spacer
    By Msport in forum Employment Opportunity
    Last Post: 09-24-2008, 07:21 PM
  3. Need bid price for some simple aluminum pieces.
    By Crazy Phantom in forum Employment Opportunity
    Last Post: 11-27-2007, 02:22 PM
  4. Rising price of aluminum!
    By widgitmaster in forum CNCzone Club House
    Last Post: 07-22-2007, 08:44 PM
  5. Price for Aluminum
    By DieGuy in forum General Metalwork Discussion
    Last Post: 11-28-2005, 06:22 AM
