Results 1 to 1 of 1
Thread: Rough Estimate needed
    Oct 2005
    I need a rough estimate on the cost to either mill/turn or rapid prototype the attached part. I plan to take that and do a bunch of fine detailing by hand and then pull a rubber mold off of it. I can build it up by hand from the getgo but I figured it would be worth getting a rough estimate. I'm not particular as to the material, so long as it is not a steel or something so flimsy that i would be unable to work it by hand with a file to add detail.
    the file may or may not have successfully been attached to the post, so a link is below
    https://docs.google.com/open?id=0B-h...YTZyYjdHMkpnZw
    thanks
    greg
    Attached Files Attached Files
  1. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-25-2010, 11:45 PM
  2. Need Help!- V23 run time estimate?
    By cut more in forum BobCad-Cam
    Last Post: 05-08-2009, 02:40 PM
  3. How to estimate the value of my used machine
    By 1ctoolfool in forum Haas Mills
    Last Post: 01-22-2008, 11:11 AM
  4. calculating a rough estimate for bearing dynamic/static load
    By margni74 in forum Linear and Rotary Motion
    Last Post: 08-20-2007, 11:20 PM
  5. RFQ: Estimate Needed On Small Steel Adapter WatchMaker?
    By mabmojo in forum Employment Opportunity
    Last Post: 12-26-2006, 02:34 PM
