Results 1 to 3 of 3
Thread: Need 18" OD plastic pipe squared up near Austin
    Jun 2007
    I got a large chunk (about 4' long) of C-905 plastic drain pipe from the guys putting it in the ground. I would like it cut into 2 pieces, nice and smooth on each end. They need to be smooth so they'll make an airtight seal for a vacuum chamber. A little too much to ask of my Sawzall. Doesn't need to be CNC, just a big lathe.
    This pipe is heavy, so it's not really cost effective to mail it.
    Thanks, Lee
    Apr 2007
    Hi, what vacuum quality are you targeting ? Plastic pipe is pretty porous to air flow, and it will likely outgas for years.
    - vacuum levels like 0.1 atm, it might work.
    - If the goal is 0.01 atm, it will take one heck of a pump to keep up
    - Below 0.001 atm is unlikely with plastic pipe, unless it is specially made for the task.
    Jun 2007
    29 inHg for degassing RTV silicone used for mold making. The pipe has almost 1" thick walls.
  1. Will a 13mm bearing fit on a 1/2" pipe?
    By Ncrazyballa in forum Mechanical Calculations/Engineering Design
    Last Post: 02-14-2012, 07:21 AM
  2. RFQ: 5/8" x .455" clear plastic rods, perfect for CNC lathe
    By Riceburner98 in forum RFQ (Request for Quote)
    Last Post: 01-10-2012, 07:44 AM
  3. 16" Pipe Headstock
    By nomangadiwala in forum Mechanical Calculations/Engineering Design
    Last Post: 09-11-2011, 03:53 AM
  4. Build Thread- need help with 2.375" w/ 11.5 tpi on a pipe
    By buffaloguy in forum General Metalwork Discussion
    Last Post: 04-30-2011, 09:35 PM
  5. Need Help!- Looking for a Supplier for 5" and 6" squared gauge blocks.
    By Stampede in forum Calibration and Measurement
    Last Post: 07-24-2008, 05:16 AM
