Results 1 to 5 of 5
Thread: RFQ for 4 Prototype Aluminum Blocks
    Jan 2012
    I would like quote for 2 of 116-789350 and one each of the ludl_support* parts. All are 6061 aluminum blocks. Drawings are attached - 3D files available if it helps. Preference towards local Pittsburgh, PA shops, but anyone can offer quotes. If we like the work (including price and delivery time), we could use you again for small jobs and prototype work. Thanks!
    Drawing Corrections:
    the m6 tapped holes in the ludl_support* drawings should be 6.6mm UNTAPPED thru holes. the counterbores are 11.2mm diam and 6.0mm deep
    Attached Files Attached Files
    Aug 2010
    c-bore
    Can you provide details of c-bores? Depth/diameter?
    Jan 2012
    drawing corrections
    The m6 tapped holes in the ludl_support* drawings should be 6.6mm thru holes for an m6. the counterbores are 11.2mm diam and 6.0mm deep.
    Jan 2012
    quote
    h
    Registered cncspec.com's Avatar
    Dec 2010
    Hi kheff,
    Is the job still open?
    Thank you,
    Sam
    cncspec.com
    1. Prototype Aluminum Enclosure
      By pilotptk in forum RFQ (Request for Quote)
      Last Post: 09-22-2011, 10:52 AM
    2. Need Help!- Help with purchase recommendations: small CNC mill for prototype aluminum?
      By jkujawa in forum General Metal Working Machines
      Last Post: 05-21-2011, 06:46 PM
    3. Three prototype ram blocks required
      By Mudgey in forum Employment Opportunity
      Last Post: 07-28-2010, 03:34 PM
    4. Aluminum end bearing blocks
      By woodworker2 in forum EBAY ADS
      Last Post: 04-01-2010, 05:39 PM
    5. RFQ Simple Aluminum Bearing Blocks
      By b0gh0s in forum Employment Opportunity
      Last Post: 12-23-2004, 04:57 PM
