I'm looking for a quantity 5 of a 2.5" round disc x 0.25" thick with a 0.030" chamfer on both faces.
Outside diameter should be a fine finish approx 32 or better (will not be tested unless questionable).
Both faces should be an ultra fine ground (appearing, 16 or better) finish. They can be face turned but no tit is acceptable. Grinding is preferred if possible.
Titanium grade not important.
Overall diameter and thickness tolerance is +\- 0.025"
Please only email me as I likely won't be able to check this often. Stizzit@gmail.com
