LASER/WATERJET RFQ: 10ga (0.1345") Stainless Prototype Job
Results 1 to 4 of 4
Thread: LASER/WATERJET RFQ: 10ga (0.1345") Stainless Prototype Job
    Oct 2017
    Default LASER/WATERJET RFQ: 10ga (0.1345") Stainless Prototype Job
    Project: ST Clamp Prototype
    Please Quote: Laser cutting
    Material: Stainless Steel 10Ga (0.1345") T304 2B/Mill Finish
    Quantity:
    Part A - 2 copies
    Part B - 2 copies
    Part C - 4 copies
    Notes and questions:
    Hello, my name is Daniel. I'm located in the Chicagoland area. I'd like the prototype job detailed above to be quoted. I've included dxf's and PDF's for each part as well as an example layout(Layout.dxf) that has 4mm spacing between the parts. You may use this layout for the prototype job if it is sufficient. I also plan on having a bigger job ran later of 100-200 units.
    I also have some questions below. Thanks!
    Do you stock the material requested?
    Do you offer vibratory tumbling?
    Do you offer tapping? Specifically M8 tap in the center hole of Part C.
    Regards,
    Daniel
    Attached Files Attached Files
    Aug 2010
    U.S.A.
    Default Re: LASER/WATERJET RFQ: 10ga (0.1345") Stainless Prototype Job
    Most will not download and open a zipped file (I'm one of them), why don't you upload the pdf(unzipped), or e-mail the files.
    Oct 2017
    Thanks for the interest to all those who replied. The job has been filled.
    Member konwey's Avatar
    May 2017
    China
    I have the experience to finish these parts
    I have sorted out the price
    Please contact me at kon@cncmachining.cc
    Thanks!
    Over 15 year in cnc machining parts business.CNC Turning, Milling, Drilling, Planning, Grinding, Welding ./www.plusminusthree.com Email?kon@plusminusthree.com
