Milling simple shapes out of 20mm x 20mm panel
Results 1 to 4 of 4
Thread: Milling simple shapes out of 20mm x 20mm panel
    Sep 2017
    Default Milling simple shapes out of 20mm x 20mm panel
    Hello,
    I am looking for someone to mill out shapes on a piece of 200mm x 200mm piece of material (DXF will be provided, picture attached). The material can be anything with a minimum thickness of 7mm.
    Basically I have a circuit board that needs to sit flat when turned upside down. The shapes in my drawing represent the outlines of the parts (+ some buffer). As long as those shapes are milled out, the parts will sit in the cavity nicely and the board will sit flat. There is no 'minimum radius' spec per se.
    Deadline is as soon as possible. I will provide shipping label for expedited shipping. Ship to Akron, OH USA
    Payment method: Flexible (Paypal?)
    Let me know if there's any questions.
    - Roy
    Attached Thumbnails Attached Thumbnails Milling simple shapes out of 20mm x 20mm panel-capture-jpg
    Mar 2016
    Default Re: Milling simple shapes out of 20mm x 20mm panel
    Quote Originally Posted by crs831 View Post
    Hello,
    I am looking for someone to mill out shapes on a piece of 20mm x 20mm piece of material (DXF will be provided, picture attached). The material can be anything with a minimum thickness of 7mm.
    - Roy
    Are you serious or just pushing people to your links? 20mm or 200mm?
    Sep 2017
    This is a serious request. I have no idea how those links appeared...
    Sep 2017
    I found a supplier. Thanks everyone.
