RFQ
Results 1 to 1 of 1
Thread: RFQ
    May 2006
    Default RFQ
    Need 6 -12 small electrode parts. brass or copper,
    A 3D solid model available in IGS, X_T, STP, mcx9 format
    2d pdf also, 1200dpi 1-1 scale
    Parts to be net or -.004 except for hole ce-ce spacing
    Parts designed for hi volume stamping, need first prototypes.
    Deburr, Top radius and polishing i will do (I use a lot of files)
    Thanks,
    Brian O.
    Customer is in 314 area code if you are nearby.
    Attached Files Attached Files
    Been doing this too long
RFQ
RFQ
