Small Machining and Tig weld Needed
Results 1 to 3 of 3
Thread: Small Machining and Tig weld Needed
    Oct 2006
    Exclamation Small Machining and Tig weld Needed
    Hello
    Need 4 small parts made, but it seems like the easiest way is to make top and tig onto shaft
    Need quick turn around about 1 week from go ahead.
    Please qoute with parts and 2 day shipping
    thank you
    Mark
    Attached Thumbnails Attached Thumbnails Small Machining and Tig weld Needed-swivel-arm-jpg   Small Machining and Tig weld Needed-swivel-arm-pdf
    Jan 2011
    Default Re: Small Machining and Tig weld Needed
    I'd just make it out of a solid piece. Missing some dimensions, can it be made from 1" square stock?
    Member LeWhite's Avatar
    Dec 2011
    Pleased to quote Please email lewhite56@yahoo.com for clarification of print and usage. Thanks in advance for the opportunity.
