Quote needed ASAP on parts made from mostly 416SS and some from CRS & aluminum
Hello I need a quote for the attached prints ASAP. The 416SS components will need to be hardened and ground per instructions on the prints. The steel and aluminum parts will need plating and anodizing as well. I will need these completed in 4wks.
Re: Quote needed ASAP on parts made from mostly 416SS and some from CRS & aluminum
The quantity needed of each part is below.
QTY. PART NO. DESCRIPTION
1 549806 BRACKET, Y CYLINDER LENS
1 549807 MOUNT, CYLINDER LENS, 22 x 20
1 549810 CLAMP, POLARIZER
1 549811 CELL, POLARIZER
1 549812 MOUNT, POLARIZER-PBS
2 549817 BRACKET, LINE CAMERA
1 549818 BASEPLATE, BAS
2 550183 MOUNT, LINE CAMERA
1 550191 BLOCK, BS MODULE
2 550192 MOUNT, CYLINDER LENS, 20 x 22
2 550195 MOUNT, CYLINDER LENS, 32 x 30
2 550196 BRACKET, X CYLINDER LENS
Your files are all jumbled up/corrupted. Drawings show, but all specs/letters/numbers are replaced with jumbled up symbols. I sent you a pm please email working pdf's (preferably or update with working pdf's, thanks.
