RFQ Small ABS Sheet
Results 1 to 8 of 8
Thread: RFQ Small ABS Sheet
    May 2015
    Default RFQ Small ABS Sheet
    Looking for 1000 or 2000 pieces. 4mm thick ABS sheet machined to a part 40x24mm in size.
    +/- 0.2mm except for one hole that is +0.2mm
    See Attached Drawing. May appear as a black image in the preview below.
    Attached Thumbnails Attached Thumbnails RFQ Small ABS Sheet-45-1310-motor-mount-drawing-pdf   RFQ Small ABS Sheet-45-1310-png
    Attached Files Attached Files
    Apr 2008
    Default Re: RFQ Small ABS Sheet
    I'm interested. Davy182@gmail.com. I'm located in Sarasota Fl.
    Jul 2009
    pmed you
    May 2015
    Glad to hear it. You are close by. Please PM us with a price for 1000 and 2000pc
    - - - Updated - - -
    Thank you, we will get back to you next week.
    May 2015
    Pm Sent.
    Thanks, Matt Mittler
    Mittler Machine Works
    matt@mittlermachineworks.com
    Apr 2008
    I will get you a price by Monday. I also do retainer work if you have other stuff that you get machined, it can drastically lower your costs the way I have it set up.
  7. #7
    Apr 2008
    pm you
  8. #8
    May 2015
    Request is filled
RFQ Small ABS Sheet
RFQ Small ABS Sheet
