Delrin tubes
Results 1 to 2 of 2
Thread: Delrin tubes
    Nov 2010
    Default Delrin tubes
    I need some Delrin tubes made. I have attached a really crude drawing. Hopefully you can follow it. LOL.
    Tolerances are loose. Say +/- .010 for everything besides the smaller, long diameter of either .5" or .535". On those, .005" is still fine so still loose. Should be a nice simple project.
    I need a couple of different lengths and minor diameters. Hopefully my description below will help with any questions.
    For the 1.125 and 1.5" measurements, the raw material can be used for this. No need to grab larger diameter material and turn it down.
    I am hoping for a 3-4 week delivery time frame.
    If you can email me at erikdye@gmail.com, that is best. I dont log in here often.
    Thanks!
    1.5"
    13pcs .500 diameter x 2.48 OAL
    20pcs .535 diameter x 3.308 OAL 15mm diameter counterbore x .195 deep
    1.125"
    6pcs .500 diameter x 4.17 OAL 17mm diameter counterbore x .125 deep
    9pcs .500 diameter x 2.39 OAL 17mm diameter counterbore x .125 deep
    20pcs .535 diameter x 5.188 OAL 17mm diameter counterbore x .125 deep
    18pcs .535 diameter x 3.218 OAL 17mm diameter counterbore x .125 deep
    13pcs .500 diameter x 4.1 OAL 15mm diameter counterbore x .195 deep
    20pcs .535 diameter x 5.108 OAL 15mm diameter counterbore x .065 deep
    Attached Thumbnails Attached Thumbnails Delrin tubes-1-5-tubes-copy-jpg
    Nov 2010
    Default Re: Delrin tubes
    This is taken care of. Thanks
Delrin tubes
Delrin tubes
