Do you need only the mount bracket for the trimmer or the entire arm assembly built?
Hey guys. I need a tool holder made that will fit a laminate trimmer and allow for rotation about the Z axis. Also a sort of stylus mounted to the assembly that will act as a depth of cut stop. Any one interested? What might this cost?
Here are some images of an older version. The one I need has to work with the newer bosch laminate trimmer offerings. I have everything but the tool mount sorted - instead of the wooden arms I'm set to use one of these:
thanks
