Need 7 items cut on a 4 x 8 CNC router South Florida area. DXFs attached
Hi All,
I need the attached files cut in 3/4"(18mm) best grade Baltic Birch. 3 of the delta printer file which is around 24" in dia and 4 of the vr spline file which is 23" wide and 78" long. The long item has a line at the 60" mark so it can be cut in two pieces since true Baltic Birch is 60" I'm located in Pompano but will drive a ways to get this done.
