No, there's no router that will do an effective job at routing out pans from billets of cast iron - not even an expensive one. If you want to use one to help you make items in cast iron, create patterns in wood that you can send out to a sand-casting shop; they will be able to produce all the pans you want much more efficiently that even a full-sized mill can.
