- CNC Record 220 w/ NUM 1080
I have a CNC Record 220 w/ a NUM 1080 controller. Trying to find out as much information as I can about the machine, particularly I am trying to get the drip feed set up on the machine. It says there is a feature, but that drip feed mode is not turned on. Can't seem to figure out how to turn on the drip feed mode. Side note the display is all in French, which is not the biggest problem, but anyone know if its possible to change it to English?
- You may not post replies
- You may not edit your posts
Forum Rules
