I wonder if there are any cnc router machines that can cut real detailed inlay work and the veneer to go in the inlay or is it better to use a Laser cutter for this?Similar Threads: Have you made any wood inlays with this machine? Wood Made In USA Sign with PVC letter inlays Need help CNC router stone work wood fine too??? Sheetcam, Donek Tools Dragknife, and Wood VeneerProblem- Wood Inlays
limitation is on the cutter diameter on the pocket side ...unless the wood is thick enough to use the vcarve method...
View Tag Cloud
Forum Rules
