Can this shape be produced in wood on a CNC engraver?
Results 1 to 9 of 9
Thread: Can this shape be produced in wood on a CNC engraver?
    Sep 2016
    Default Can this shape be produced in wood on a CNC engraver?
    Consider these hand-carved letters in stone. See the form at the ends of the legs of the A and the top and bottom left of the B? Can that particular form be produced in a CNC router/engraver? Intuition tells me it is impossible with a rotating cutter, and yet I have seen that in wood. I suppose it is hand carved there as well, or can it be laser-engraved?
    http://1.bp.blogspot.com/-fd6BHK6Lk2.../s1600/075.JPG
    Cheers
    Registered CitizenOfDreams's Avatar
    Nov 2012
    Default Re: Can this shape be produced in wood on a CNC engraver?
    V-shaped cutter. The variable line width is achieved by changing the depth of cut.
    Registered KH0UJ's Avatar
    Jul 2016
    Philippines
    V-bit + Vcarve software = kinda like that but V-bit + custom CAM = exactly like like customize a little more = more than that
    Gold Member daniellyall's Avatar
    Sep 2009
    New Zealand
    Simple answer yes it can but not quite as sharp of a corner it's called Vcarve or engrave. Have a look at Vectric Vcarve pro Products - VCarve Pro
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    Apr 2003
    Arizona, USA
    Also Vectric Aspire & Arcam. This is pretty basic stuff for either software. There are others that will do it besides those already mentioned.
    Mar 2003
    F-Engrave, which is free.
    UCCNC 2017 Screenset
    http://www.thecncwoodworker.com/2017.html
    http://www.thecncwoodworker.com/2010.html
    http://www.g-forcecnc.com/jointcam.html
  7. #7
    Sep 2009
    New Zealand
    Fusion360 can do it as well
  8. #8
    Gold Member
    Jun 2010
    All of the above, ASSUMING the groove angle is fixed!
    That means the grooves in most of the letters will have varying depths. But that would be expected for this font.
    Cheers
    Roger
  9. #9
    Nov 2012
    Another piece of software capable of doing this is V-Engrave plugin for CamBam.
