Need Help! tool change hieght plate
Results 1 to 6 of 6
Thread: tool change hieght plate
    Feb 2012
    Default tool change hieght plate
    Hi Guys
    I am not really good at explain things so I am going to try to show pictures of what I am trying to do. First my machine worked 1 year ago with this function but I had it shut down for a year remodeling my shop and had some issues restating it.
    What I am trying to do is set up my tool change plate and cant remember how to do it.
    This is what I have done so far.
    set up my home switches as follows
    plug 1 a axis slave to Y pin 12 (Top left plug )
    plug 2 y axis pin 13 (top right)
    plug 3 x axis pin 10 (second row left)
    plug 4 z axis pin 11 this a my touch of plate for ne jobs to set the height of the (material. not really a home (second row right)
    plug e stop pin 15 (bottom plug 2 pins)
    I am using a gecko g540 board. All the above switches activate on mach 3.
    1st picture my plug board on my machine the numbers don't match up to the above pin numbers is this an issue
    tool change hieght plate-20160709_203630-2-jpg
    plugs plugged into slots
    tool change hieght plate-20170305_204840-jpg
    tool change hieght plate-20170305_203930-jpg
    Input screen not sure why x is pin 10
    tool change hieght plate-20170305_203854-jpg
    Seconds page on mach
    tool change hieght plate-20170305_205012-jpg
    my touch off plate
    tool change hieght plate-20170305_204933-jpg
    I have on plug left.
    I am not sure where to plug my plate into.
    Any help would be appreciated.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: tool change hieght plate
    Why are you using that board, and how is it connected to the G540?
    UCCNC 2017 Screenset
    Feb 2012
    This is a older machine I built 4 years ago.. here is a picture of how it is hooked to the g540
    Back of the plug board
    tool change hieght plate-20170116_183543-jpg
    Gecko board
    tool change hieght plate-20160615_201803-jpg
    Mar 2003
    Shelby Township
    The plate can go to any of the 5 input pins. It needs to be assigned to the Probe input.
    Feb 2012
    Quote Originally Posted by ger21 View Post
    Thank you for the reply I will try this tonight.
    Feb 2012
    Quote Originally Posted by hockeyguy01 View Post
    Thanks Garry I did it tonight and it worked perfect.
