Hello,
I have the machine hitachi seiki VK 55II with seico 10 control. and now I can't reset the alarm [742] Editing the program. Does any one know how to fix this alarm. I need your helps.
Thank you!
Helllo guys i just got a Seiki Seicos my2 and i have some smalll problems . My machine had 5 axis some time ago . Some one stole the 4x5 axis from the machine and cut the wire . I have managed to get the wires out . started the machine and i need some how to get out the 4x5 axis from the software so i can work with the machine in 3 axis as i want . Did some one have made this modification ? i have fix the hard limit . I cant find in the manual how to get out the extra axis .
Hello,
Thank you!
Hi!
We have a big problem on a machine HITACHI SEIKI VM40 with SEICOS M2 control, year 1988, SN No:40309,
the machine was working just fine until the battery alarm appeared on the screen 033 BATTERY ALARM
the both batteries were changed while the machine was powered off (unfortunately big mistake)
on the screen we had:
at first BUBBLE READ
and then after a few seconds
PC NOT READY
SEICOS
mark 2
when we press NC/PC and then IINPUT the messages on the screen are:
SUM CHECK ERROR SEQUENCER NOT READY
BATTERY ALARM PLEASE CHANGE
We found some procedure for overcoming this status on the machine
the procedure that we conduct it is:
1. Press F1(SEQUENCE) ->Press F2(DATASET) -> Press F4(TABLE) -> You will see “Constance Byte Table 1
2. Type 0 0 (in the 1. 00) -> Press INPUT -> You will see Parameter Write Enable SW On ---------------
3. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
4. Press F6(END). -> You will see Write Enable SW Off
5. Turn off WRITE ENABLE SW
6. Press F6(END) -> Press F1(SEQUENCE) ->Press F3(PROGRAM) -> You will see Parameter Write Enable SW On
7. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
8. You will see top line of ladder automatically
9. Press F2(ALTER) -> You will see ___(Cursor) on screen.
10. Press F4(STORE) -> Press INPUT.
11. Press F6(END) -> You will see Write Enable SW Off
12. Turn off WRITE ENABLE SW
13. Turn off NC power -> Turn on NC power
After we did the procedure, we turn on the machine and we get Z80 CPU ALARM on the screen any suggestions how to continue from here?!?!
We are asking a confirmation did we apply the right procedure?
and after this we are assuming that the parameters should be loaded
we have a backup of the original parameters,
but if we need to load anything else please advise,
If this is not the right procedure please let us know
and point us for the right procedure in step by step if possible,
We don't have any experience with this machine or this control so any suggestion is more than welcome,
Thank you all in advance,
Regards,
i need electric drawing hitachi seiki va 45 fanuc 11m can you help me
vladimir, you have lost the ladder program for your mill. PM me and I will email instructions
Keshka
I have 1986-87 Hitachi-Seiki HT-20 Fanuc 10TE control cnc lathe. It was setting for a couple of months. went to hook it up and it boots up to ram test then stops and goes no further.... any suggestions?
Jim Compton
Visit www.manuals-depot.com Many tractor manuals available
Hi Jim
you might need to regen if it lost battery / data - you can pm me your email and Ill reach out to get you going
John
Hi Josh, I have an HT23J. The tool unclamp/clamp piston hit the hydraulic tool release piston while the turret was indexing, & stopped the turret. I don’t know how to get it back to zero. Can you help me with the procedure to zero it?
Its a Hitachi-Seiki HT23J with a Yasnak control.
Thank you
Mike
greelyman@mac.com
Good Day
Please can anybody help me with the datasheet for a Hitachi Seiki VA-40 Micon 8 system? All data was lost due to low battery.
I am situated in South Africa. You can email me, jacof@mweb.co.za.
Any help will be appreciated and thank you in advance.
Jaco
Dear friends,
How to set zero return procedure on Hitachi Seiki VM 40II,seicos 3?
Thank You,Have a nice day
Rizal
Hello
what do you mean? Did you lose data and now it is not going home but oevertravelling?
After SPHC card has changed,now the machine always overtravell when zero return performed
Thanks for your attention Mr John
Hi All
I have hitachi seiki st200, Seicos Pcflexi control.
Alarm 700044 EMG-STOP pressed. DB2. DBX185.4
Su--
Hi Hitachi_man
I have hitachi seiki vk45 vmc Ladder corrupted,No pack up and no YU YU software can you please help me
Hi
