Er, it's only a matter of facing, drilling and tapping four lengths of steel rod,
The joints are 18mm lengths of 1 1/2" x 5/16 ally extrusion (bent in a vise where necessary)
The rose joints are cheap pressed steel ones. They had a bit of play, but this is easily removed by (using a pair of old bearings as anvils) squeezing them in a large vise.
Making the post clamp is going to be tricky. Simply holding the piece, while boring a 115mm hole will be a challenge. But, none of it is difficult. The only difficulty with the roller nuts is fitting the ****** things to the mill.
If you have a lathe and a mill of some description you can do it too
