Fogbuster Repair
Results 1 to 2 of 2
Thread: Fogbuster Repair
    Member scott216's Avatar
    Apr 2012
    Default Fogbuster Repair
    Somehow the threads in my fogbuster got messed up. I ordered an new needle valve from Hench, but when I tried to install the new needle valve, there was a lot of resistance. It seems the internal threads may be messed up also. I'd like to get a tap and clean up those threads. Anyone know what thread is used for this? It's pretty close the M5 x 0.8, but the diameter seems a little bit smaller than an normal M5 screw - it's about 4.75mm.
    "You can't teach stuff in a school that you would learn in real life unless the real life people are in charge of the school." - Gene Sherman
    Apr 2012
    Default Re: Fogbuster Repair
    I figured it out, it's a 10-32 thread.
Fogbuster Repair
Fogbuster Repair
