I am looking to get a new larger CNC brake press. I am looking for reviews, comments, opinions, experience, etc. Only want a 6' press for light gauge aluminum and steel. what 2 axis CNC. 40Tons of more. Currently looking at these two, which are both in the $25k range. Leaning towards the US Industrial, but don't know anything about the company or brand name.
Option 1: 44 Ton x 6' Brand New U.S. Industrial CNC Hydraulic Press Brake, Mdl. USHB44-6, CNC 2-Axis Color Graphic Control, Sick 4000 Safety Guarding Light Curtain System, Ram Deflection Adjustment, Mechanical Ram Depth Control, Massive Torsion Bar for Parallelism, Forged Heavy Duty Cylinder and Cylinder Body, Three Speed Ram, Rapid Approach, Bending Cycle and Rapid Retreat, Bottom Time Delay, Inching, Single Cycle and Continuous Operation, Ram Takes Standard American Tooling (1/2" x 5/8"), Space Between Ram Tool Clamps Allows For Deep Box Bending, Bed Has Slot For Standard American Tang Tooling, Bed Also Holds Tooling With Capture Clamps, Free Gooseneck Punch & Multi-Opening Die for Up To 90 Degree Forming in 10 Ga. Mild Steel, All Steel Construction
Option 2: 45 Ton x 6' Brand New Baileigh 2 Axis CNC Programmable Vertical Hydraulic Press Brake, Mdl. BP-5078CNC, 45 Ton Maximum Pressure, 78.7" Table Length, 2 Axis Control, Repetitive Accuracy within 0.04mm, Light Curtain, Industrial Grade Hydraulic System, Adjustable 2 Step Downward Travel, Quick Release Tooling System, Ball Screw Back Gauge with Linear Guide Rail, Accepts Any Standard Press Brake Tooling, Foot Pedal Controlled, Multi Vee Bottom Die & Gooseneck Punches with Quick Change Holders, 220V~3 Phase
