Tried to upload videos but it will not let me.
I just joined. I have looked at the page a few times for ideas over the past year. I figured I would share my creation with everyone here. Feel free to ask any questions. I will post pics from my phone in a few.
My control wiring is a mess right now because I just switched a bunch of stuff from steppers to servos. But I'm running Mach 3 with a smooth stepper no breakout board other than the smooth stepper. A hertz 2.2 spindle with an er25 collet and a delta vfd. I have thk shs 35 rails on my Y axis thk srs30 rails for my X axis and a double thk kr45 actuator for my z axis. This is the 4th machine I've built now to achieve the results I've been looking for in metal cutting and surface finishing. Im able to machine aluminum, steel, and stainless. I've finally gotten the machine stable enough to run aluminum with an 1/8 step down at 250 ipm at 15000 rpm
this is my machine that used prior to my new one and also what I used to machine all the pieces for my new machine as well.
Here's a link to the machine in use.
New tool tray to keep it all off the floor
New video
Great work! Interested to hear your impression on the servos you used. Which did you pick? Seems similar to the ones posted on aliexpress.
Yes there Chinese servos. 3000 rated rpm .75kw. I have one that keeps losing position when I run over 300ipm but I believe it's the belt drive skipping a tooth from the torque. I'm waiting on my last zeromax coupler and they will all be direct drive. Then I'll know for sure what the problem was. Also I had to change a bunch of settings in Mach for my computer to be able to talk to the machine fast enough.
Could you tell us more about Mach 3 settings?
I had to calculate the steps and match it with the correct MHz for the drive in the settings for my ess. Also had to set the buffer length to 4mhz. I also changed the step to 1 and the signal to 2 in the motor tuning. I'll have to think of what else I changed.
Machining a 26x12x1 steel plate. The largest I've ever attempted
Never had these results when running steel.
Used a sandvik 6flute super high helix finishing bit
Dillonfitz, great machine. I built a similar style machine a while ago out of Epoxy Granite. I was thinking of using similar motors, although I'd prefer to use them in analog control mode with feedback to linuxcnc. How do you find the step direction control?
Thanks.
The drives that I use use the step and dir outputs just like stepper drives. There's a parameter within the servo drive to set the input to digital and also within he smooth stepper confit I unchecked the step/dir box and checked the cw/ccw
Cutting a new motor mount to bolt to the ball screw bearing block. Starting with a 6x6x2 block of 6061. I will put up a pic when it's done cutting.
Cool machine! Looks very capable. I'm also using the KR actuators on my Z and they're working really well. Do you find any difference in accuracy of the parts for the different axis?
Sent from my SM-G900I using Tapatalk
