Need Help! Re-finishing a refurbished lathe
Results 1 to 6 of 6
Thread: Re-finishing a refurbished lathe
    Registered Endlesshunt's Avatar
    May 2016
    South Africa
    Default Re-finishing a refurbished lathe
    Hi
    I'm currently rebuilding/refurbishing my old chinese lathe and need some advice on the re-finishing of it.
    I plan to use a self-etching primer as a base layer and then some high fill undercoat for on the painted parts of the lathe.
    My question is that there are some parts that will need body filler to get some bad spots covered, do I used the body filler directly on the metal or first use the self-etching primer with the body filler on top of the primer?
    Also what type of paint would be the best to use for the final colour coats?
    Regards
    Deon
    Jan 2005
    Default Re: Re-finishing a refurbished lathe
    in automotive body working circles the common consensus is that body filler only goes on bare metal, or on metal that has been EPOXY primed. No other primers are recommended.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    I'd make my own filler with epoxy and a filler, like microballoons. This is a much better filler then bondo.
    UCCNC 2017 Screenset
    May 2016
    South Africa
    Thanx for the info. I still have microballoons left from my RC days so will use it.
    Any advice on the best paint to use?
    Jul 2014
    Quote Originally Posted by Endlesshunt View Post
    Hi
    Regards
    Deon
    I would watch all of Keith Ruckers videos on you tube where he restores an old Leblond lathe. Primer is not needed. Cast Iron is porous enough that it does not need a primer. It just needs a high quality outdoor industrial enamel.
    I see no need to fill in small imperfections but that is up to you. Large cracks and holes maybe. The cast iron just needs to be clean and bare with all rust removed. This is a series of videos. I think #4 is where he paints it.
    https://www.youtube.com/watch?v=LZ31m-QtOHw
    May 2016
    South Africa
    Thanx, I'm actually subscribed to his channel but did not watch that series yet. I will definitaly go watch it.
