Do you have JZNC-IOP panel ? What type? Language is code in panel.
But i can see in manual at monday.
I have a Enshu S400 with Yasnac J100M
Display language now is Japanese.
I found that could change to English but I dont know how to do that.
Anyone could help me
p/s I used way in Seicos III( I see that it similar with yasnac ) is change parameter 9001 from 0 to 1 but nothin happens.
- Need Help!- Need Help with Yasnac J300 controller! Alarm codes
- Need Help!- Matsuura, Yasnac j100/j300 parameter help
- Need Help!- Hitachi HT 20 J lathe with Yasnac J300 control
- Need Help!- DPRNT command in Yasnac J100
Can you find model of LCD ? it can be JZNC-OIP04J J on end is japan, E english, 04is type ( 01 02 is crt horizontal/vertical 04,05 is EL horizontal vertical).
Hello, i check and i dont find it in my manuals. But you are right, it can be change by parameter. Do you have paremeter list? that we can compare it with my?
I have but no parameter show about language to change.
What model do you have.
I download from yaskwa. J100 and J300 are same
https://www.yaskawa.com/downloads?p_...+-+User+Guides
I have also yaskawa yasnac J100.
If you send me your parameter i can compare with my and may be we find difference. Standard language is English/Japan. It can be change by parameter. German and some other language are activate as Option ( pay separately). You buy with Japan language? What size of internal memory you have? Do you have CF card?
Do you have email. My email is terminaterx300@yahoo.com
So many parameter. I think some is about servo spindle IO. What should is send.
I dont have CF card. I buy with Japanese language. My friend tell me that i80 can change from parameter
Here is parameter list. What parameter you think related to language and I will to send your email
hello x300.
i have a machine like your machine with j100m control and i have problem in pooting of control and i must clear memory and put all parameters and option parameters again on control.but i have not any backup of parameters.can you please send me a copy of your machine parameters and options parameters.
thanks.
inbox me
The language can be selected by OPM16 Bit 0 0=Japanese 1=English
