Chinese XK7130 a complete experience Review! - Page 28
Page 28 of 28 FirstFirst ... 1825262728
Results 325 to 331 of 331
Thread: Chinese XK7130 a complete experience Review!
  1. #325
    Aug 2008
    Default Re: Chinese XK7130 a complete experience Review!
    Quote Originally Posted by ebrewste View Post
    0.011" per tooth? That's not messing around Looks like fun!
    for sure!!.. that is a healthy cut for certain, wouldn't hurt to have some more power in the spindle.. considering upgrading the spindle and spindle motor, from 5.5kw to 7.5kw and bumping the speed range up yo 12k rpm and new spindle to handle it. at the time of originally purchase the funds were not available for that upgrade, but maybe in a few months they will be. seeing as we process 90% aluminum it makes a lot of sense.
    Sent from my XT1585 using Tapatalk
  2. #326
    Sep 2017
    Great Thread ! Thanks for all the documentation ... very insightful. Hope you get this Linux CNC thing all sorted as well as much success with your new baby.
    All that said .. bro - I need these connectors in my life ... where can I find these ?
    Chinese XK7130 a complete experience Review!-16465282_331633907232319_654665144621596672_n-jpg
    Attached Thumbnails Attached Thumbnails Chinese XK7130 a complete experience Review!-16465282_331633907232319_654665144621596672_n-jpg
  3. #327
    Aug 2016
    They look like GX16 connectors
  4. #328
    Gold Member jalessi's Avatar
    Feb 2007
    Items for Sale
    The connector appears to be a GX 25-4
    See attached links:
    https://www.aliexpress.com/wholesale...rchText=GX25-4
    https://www.ebay.com/itm/Aviation-Pl...kAAOSwLmVXEOsX
    Jeff...
    Attached Thumbnails Attached Thumbnails Chinese XK7130 a complete experience Review!-gx-25-4-jpg
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  5. #329
    Jul 2016
    Did you ever get a chance to check the runout on the BT30 tool hoolders you got from tool tree? I am looking at ordering a set of BT40.
  6. #330
    Oct 2013
    Chris,
    I read this entire thread..great job. I'm still not clear on the status of your machine though, is it finished and running? The videos appear to be the other fellows machine..correct. Did I miss something, I know you were a bit stymied on your control system, did you get that sorted out?
    Thanks,
    Stuart
    "THE GRIZZ" photo album - https://goo.gl/photos/yLLp61jooprtYzFK7
    Youtube - https://www.youtube.com/channel/UCT2lq9obzEnlEu-M56ZzT_A
  7. #331
    Aug 2008
    Quote Originally Posted by atomarc View Post
    Chris,
    Thanks,
    Stuart
    Stuart,
    My machine moves around but not finished with the CNC control yet. While I pulled the shop apart for running the wiring and phase converter connections for this machine I have taken the opportunity to run wiring for various other machines around the shop for future upgrades, run a full shop airline system 300 feet with 9 spigots, and add new shelving and organization through out the entire shop. I have a small business that is run by myself so it takes a majority of my time keeping up with that. I also in the interim run my grizzly for making my parts which gets the job done albeit a bit slower than the new machine should be able to do with less intervention. Once everything is wrapped up with the rest of the shop updates which were a matter of convenience during the big machine wiring and pulling the shop apart for wall access, I will return to the control wiring which should not take to much time as I now have everything needed and a finished schematic I built for all the control wire runs!
    I will post up some pictures of the shop once it's completed, I'm pleased to say its really taking shape nicely and was a long time coming. I had originally needed to move out of my commercial building into my home shop rather quickly and also out of the apartment we were renting into the house I built, so I didn't get to do some of the things I wanted back then. Now that I had that opportunity it was a no brainer to go ahead and Debbie the time and money to it!
    Chris
    Sent from my QTAIR7 using Tapatalk
