Managed to slip back again to the shop
New spindle set into the tapered roller brg; this will be finish cut to fit the chuck under power in the brgs; the collet taper and some small detail can be done then too; this will ensure accuracy
The back view; still need to make the locking threaded coller; but the 1.000" dia is finished ready for the drive pulley; this is longer than the single 8 step pulley I was using to allow for a timing pulley to be added just behind the lock coller; this will be for indexing the spindle with a 310oz/in stepper 3-1 reduction
Note the shallow keyway 0.125 deep 0.1875 wide I kept it shallow because the hole through is quite big 23/32" dia
Next will be the lock coller and mod the pulleys; the extra depth in the bores is for the oil seals 55mm 38mm 8mm
